Precis- house has been empty for many years. Was rewired around 2004/5 I'd guess (modern ish split load CU with MCBs and 1 RCD, brown/blue links internally but red/black T & E from every breaker) and whoever did the job couldn't be bothered (or was told not) to install a sensible number of sockets in each room (1 x double) or to remove the rubber sheathed T & E (from the 30s maybe) or the conduits full of fibre insulated (doesn't look like asbestos) singles from Lord knows when.
Anyway, renovating. There was a fair bit of damp in some of the walls so some of the sockets had gone a bit corroded- no dramas, easy replace.
BUT I am getting a low insulation resistance reading from the first leg of the downstairs 'ring' (why he bothered with only 4 sockets on I have no idea but there we go)- showing 15 MΩ L-E where everything else is 100 MΩ plus. So I'd like to replace this leg but that would mean a bit of blue/brown T & E in the CU- is that a new circuit (notifiable) or a repair (not notifiable)?
Future plan (of course) is to extend the hell out of the rings (which since April 1 2013 I'm allowed to apparently). Also I'll be sorting the lighting circuits- all in red/black T & E, all insulation resistances and continuity are fine but there are about 4 big stealth JBs under floorboards which I want to get rid of for obvious reasons.
TIA
TIA
