I would have thought that the OP should replace the FCU with a good quality one which will blow the fuse before its switch contacts fail.
And ensure the double socket is a high quality item. E.g an MK one (as per datasheet above).
I'm not saying you should run 2 items together, but from what we have heard about the current setup it would sound like a good idea in case a new owner plugs two high load items in together.
