- Joined
- 27 Jan 2008
- Messages
- 29,286
- Reaction score
- 3,598
- Location
- Country
integral
adjective
adjective: integral
ˈɪntɪɡr(ə)l,ɪnˈtɛɡr(ə)l/
As I said before seems the people writing the regulations can't read or write English. All we seem to have proved is the law is a load of rubbish as the people writing it failed to say what they wanted.
However to be fair the BS7671 has been re-written and altered many times much of it to clarify points which were not made plain first time around. If you look at the TV licence law most of it is case law where some one tried to get around it and it was clarified. When I went to school the apparatus used to convert radio signals into electrical signals was called an aerial but painting the aerial black and white does not mean you can get away without a colour licence. Court cases have ruled on it.
I will guess some where some one has tried to get away with not fitting plugs or simply fitting adaptors and likely there is now case law which clarifies what we can and can't do. From the amount of items I have seen supplied with adaptors which did not need a tool to remove it seems likely some where some one has been taken to court and there has been a ruling. I would say to try and get away without supplying something which allowed the item to be plugged in your treading a dangerous path. On the other hand if an adaptor is supplied which does the job it is unlikely trading standards would waste time with a court case.
However as written and published the law is silly.
adjective
adjective: integral
- 1.
necessary to make a whole complete; essential or fundamental.
