It's often been mentioned here that using another manufacturer's MCB in a consumer unit invalidates the type testing and I have no doubt that it is the case and I have no intention of doing it. However, when it comes to finding incorrect MCBs already in use, a couple of questions arise that Guidance note 3 doesn't seem to answer clearly...
Bearing in mind that BS7671 has recently changed the requirement to comply with manufacturer's instructions.
Assuming they physically fit and the CU has not been butchered, giving rise to IP breeches, exposed live bits, etc. Would you code it on a domestic EICR and if so, what code and under what reg?
Does the same type testing apply on light commercial (63A max per outgoing way) TP distribution boards?
Again, assuming they physically fit and the DB has not been butchered, giving rise to IP breeches, exposed live bits, etc. Would you code it on a commercial EICR and if so, what code and under what reg?
