I installed an Accenta G4 metal panel with two RKP's, two bells and an internal sounder recently, all working fine....
I'm not using the PA or the Fire on the panel, just PIR's and magnetics.
I have a couple of question on the speech dialler:
1. If not using the 'Follow Me' function can you set the alarm on the RKP like I do now, or does the dialler become the main method of setting the alarm. I hoped to site the dialler in a cupboard out of the way, assuming when the alarm is set on the existing RKP the dialler become active?
2. Based on the fact I installed the panel etc with no problems, will I find the wiring of the dialler quite straight forward? Looks like its quite simple wiring into the communicator bit on the panel, then to the master socket.....
thanks
thanks
