New Consumer Unit ?
a consumer unit has a main double pole isolator and then an arrangement to permit multiple lower current circuits to be safely connected to the incoming supply. I'm not sure if a single breaker enclosure is similar enough- there's no provision for multiple lower current circuits and no distribution going on.
The definition of CU states "one or more fuses, MCBs etc".
So would that make a switched FCU a "similar switchgear assembly" then?
What do you mean by
an 8 way single RCD Consumer Unit with a plastic casing.
Is the RCD the main switch or is it a split load board (i.e. there is a main switch and the RCD only controls things such as sockets)?
I would include everything you'd normally refer to as switchgear under amd3. Certainly any form of consumer unit, definitely switch fuses, and I suppose, if you were going to fit one, not the supplier/DNO a 2P/4P isolator.
There's plenty of metal switch fuses about, and I think Wylex even make a metal REC2S now if I'm not mistaken
Can't find any, but that does not mean they are not around.
Incidentally, RS have a good price on the plastic REC2S, £11 instead of nigh-on £30.00
Yes, that is the cheapest price I have seen, the average price is around twenty-five to thirty pounds at the so-called rip-off merchants.
So what about one these:
Are they "similar switchgear assemblies"?
I would class a switchfuse "similar switchgear assemblies" yes.
Whether the IET do is another matter, but I would have thought so
Part 2 in the BYB - although I did change my mind as it starts with "a particular type of distribution board".
