They do not.
Don't worry about it.
Why?Personally I would call an outdoor socket on the same fcu as a washing machine a bodge even if compliant.
Yes, but you are desperately irrational about some things.If I found it on a house I moved into I would be changing it asap.
Possibly.Quite simply. A lawn mower and washing machine both on at the same time would overload a 13 amp fuse.
How can she be mowing while doing the washing?
If only lawnmowers were automatic, just like washing machines, it would be much nearer to a perfect world. ;0)
Possibly not.
But I'll tell you what is certain, and that is that every single house in the land has socket circuits which would overload the protective device if a number of certain appliances were all plugged in at the same time.
So given that, do you have a useful and helpful point to make, or are you just being a pointless-waste-of-space t**t?
FGS, don't start him off again.at a nominal 230volts
My washing machine is rated at 2300 watts max. My Flymo uses 1450 watts. The outdoor socket is rated at 3120 watts max.
I promise to be REALLY careful, and to not cause any explosions.
