I've created a 3m2 stud wall with C16 stud work timber. It's a cavity wall for TV audio visual system. I have sandstone tiles that are 600x150mm and weighs abut 3.8KG per tile so seems much heavier compared to normal tiles that I usually attach. That will make it over 40KG per m2.
Trying to figure out what material to use. It's a dry area without any moisture, initially was thinking to use Gypsum 12.5mm thick Gyproc Square Edge Plasterboard. Not sure if this plasterboard is going to be able to handle this. Can anyone make any suggestions please? The adhesive i've got is the Wickes Extra Strong Wall Tile Adhesive 10L
I've also come across the following plasterboard from B&Q: http://www.diy.com/departments/hard...tile-stone-l1200mm-w800mm-t12mm/136777_BQ.prd
Anyone have any experience with that? it claims to be able to hold 100kg per m2
Many thanks
Many thanks
