- Joined
- 27 Jan 2008
- Messages
- 28,625
- Reaction score
- 3,488
- Location
- Country
1 So such thing as a 17th Edition consumer unit. My fuse box is far earlier than yours and still compiled until amendment 3.
2 So what if it is, that is permissible. OK maybe also needs 30 mA as well but nothing wrong with that.
3 That is nothing to do with you. That is down to DNO.
4 Having just shown last 3 were wrong I would not worry. Above stairs then there are special requirements so it will not fall on firemen in a fire but not below.
5 Only required if fitted after 2008
6 Only required if fitted after 2008
7 It would have taken less time to replace and write it down. Missing does not auto make it dangerous.
8 I do wonder what a 1x25mm twin is? I would guess point missing so should say 1 x 2.5 mm² which is permitted.
9 At last some thing which may be coded.
10 The water boards address is found in the telephone directory.
11 So what's the problem?
12 So what is the problem?
13 To say what?
14 Not really something to cause a code. Most people would carry the stickers and just put one on.
15 Pendants are not fixed that's why they are called pendants they are free to swing.
16 Seems rather odd, I would think he does not know the difference between pendent and ceiling rose.
17 As said they should not be fixed.
18 OK something worth reporting.
19 What's the problem.
20 OK until 30 mA RCD's are fitted this could be a problem.
21 OK again needs investigating.
22 I would hope he did earth continuity of all sockets not just nearest.
23 So what?
24 How big allowed IP4
25 So what there is nothing to say you need a fan isolator it is under the wattage which requires them.
26 OK needs addressing.
27 How does he know? Often when trying to release screws one needs over the torque required to tighten them.
28 In other words he could not do his job.
There are so many faults with the report it may as well go straight into the bin. There should be two parts, one shows all items which required codes, the other any items which your attention needs drawing to but don't warrant a code. Should not combine them together. There are some valid points and these should be corrected before getting another proper one done.
The main point is the consumer unit needs 30 mA RCD's fitting before you rent out. Even if not technically required in view of the court cases where people have been injured you really need to fit them. If you have a new consumer unit most the points raised will be cured at the same time.
It has been made clear that not having a loft hatch is no longer a reason for non inspection in the loft. Be it make a loft hatch or remove tiles one has to inspect. I am glad I no longer am involved. However cutting away plaster to release a ceiling rose is rather minor compared with loft hatch he should have done it if he considered he needed access.
13 To say what?
23 So what?
