having a problem with my tv turning its volume up on its own to full blast , must say its doing my head in , has anyone any advice to fix this problem.
thanks
thanks
tried that already , cheers thouWorth trying new batteries in the remote, updating for new channels and software update if that is an option in the menu`s.
It isn`t somebody winding you up is it? I have Peel remote on my smart phone which can control my tv.
I've had a case where the volume button was "leaky" and caused this symptom. So it IS worth disconnecting it as a test. However, the fault might be in, or around, the volume control I.C. and that's trickier.TBH I've had to tv for few years , what would people think of my solution . the way I'm thinking now is the tv is fooked and before dumping the thing i thought about trying to open the back panel of the 50 inch tv and try and disconnect the wire to the volume buttons on the tv just incase the switch is damaged in some way. do you think this is to far fetch ( desperate ) ,or do you think this could be a possibility ??
ALWAYS state what you have tried already, in your initial post. Avoid wasting people's time.tried that already , cheers thou
