Sockets don't have fuses.Turns out there was no fuse in the socket for the water heater element.
If you mean a plug, water heaters - if you mean an immersion heater - should not be supplied through a plug.
You should wonder why it was removed.
If you mean another type of fuse then that is indeed a puzzle and should be investigated.No one is really sure why the heaters didn't work because of a fuse in the water tank but..
Perhaps not.problem solved!
Still - as long as it works - nothing else matters, does it?
