- Joined
- 1 Sep 2015
- Messages
- 377
- Reaction score
- 6
- Country
I just wanted to double check my workings here.
I've bought a pond pump which comes without a plug on the end.
In the instructions it says that it must go through a DP fused spur with a min contact gap of 3mm (fitted with a 3 or 5a fuse), and a 10mA or 30mA RCD must be fitted to the supply.
To check, if I run it through this fused spur (need to check it is DP)
https://www.amazon.co.uk/gp/product/B006GAI2LM/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
then wire a plug with a 3 or 5a fuse into the spur and plug it into:
https://www.amazon.co.uk/Masterplug...8&qid=1473175540&sr=8-1&keywords=external+rcd
Would that be sufficient, or since I have direct access to the socket as its right next to the spur, can I simply put a plug on the end with a 5a fuse and straight into the socket above?
