- Joined
- 27 Jan 2008
- Messages
- 28,983
- Reaction score
- 3,552
- Location
- Country
The lamp was fitted to a house wired in 1954, so original no earth, it has a metal eye bracket which screws into the ceiling which has an earth connection, but the light is suspended by a chain which is coated with a bronze looking finish, and two core cable from the metal eye bracket onwards.
I have seen many lamps with this type of connection, and question arises is there really any earth connection through a coated chain or is the earth just some where to terminate cables?
As not new any double square on the box is long gone, there is a double square on the bulb holder, but as to if that refers to whole lamp or just the bulb holder is anyone's guess.
The lamp is heavy and there is a silly post for first part of the fitting which I intend removing, I intend to replace the ceiling rose with a ceiling rose with hook which slides in so it can be all pre-wired on the ground and slid into position all wired up.
Not got the Maestro Ceiling Master rose yet, but it says metal parts so I assume the hook will be earthed, however the whole idea of taking and earth through a chain seems wrong to me. Lifting the lamp either as original or new set up will disconnect the earth even if it does have an earth through chain which seems unlikely due to coatings on the chain and hook.
I personally think the cable is double insulated and holder is double insulated so there is no need for an earth connection. However would like to hear what others think. The only real way to get an earth to the lamp is to swap the cable for three core and fit a brass lamp holder which seems to be going OTT.
It takes a E27 lamp. I will guess from some where like Ikea it looks like the typical Ikea bulb holder.
There will be an earth connection at the rose, as house now re-wired, but I feel the earth connection is only a place to connect the wires to in order to maintain earth connection to next lamp.
