Apologies for the basic question, but I have this pendant light; metal lamp holder, twisted flex, metal ceiling rose, and I need to shorten the flex. The flex has the earth wire connected to the lamp holder at one end (obv) and the rose has an earth cable attached to it under the nut in the centre. The instructions that came with it aren't exactly clear but indicate that the earth wire of the flex should be connected to the nut in the centre i.e. attached to the rose earth cable, and then the rose earth cable should then be connected to the earth cable of the lighting circuit. Bearing in mind this came from the shop like this, am I right in thinking that, to save taking the rose to bits, I could just connect both earth cables to the earth cable of the lighting circuit instead, similar to how it looks in the photo?
TIA.
TIA.
