Rough costing got 6x6m garage
25 Jun 2015
Good Morning all,
Anyone able to give me a rough cost to build a 6.4 x 6.4m detached garage with apex roof.
1) using 225m single block work with external render finish
2) apex roof using Marley cheap large grey tiles
3) Floor slab is 150mm deep with a252 steel mesh reinforcements
4) using 3 catnic lintels one above window, one above side door and on above large front garage door.
I was hoping around 10k, that's with electric etc all sorted as well fully finished. But I could be way of the mark.
If you're doing the work yourself then it sounds pretty reasonable.
A comment I'd have is if you shrink it ever so slightly so the internal floor area is less than 30m² then you needn't apply for building regs. Of course it can be useful to have the reassurance anyway, but personally I'd avoid the cost.
Cheers for the reply. I had plans drawn up and building regs have passed it off with the details above, they will still need to inspect it as I go on.
I have quotes for 11-12k for basic build.
That's without rendering , scaffolding ,insulation , drainage or services to garage, that's just the basic build, which I think is high its going to cost a lot more to get all the other bits finished off etc.
I maybe wrong through and that's the average cost these days.
Would it help if I said £9999.99? But then again I would not be building it.
You need to get local quotes and those are the costs.
But those quotes you have already are bizarre. If someone quotes for a job, they don't leave out render, scaffold, drainage, insulation and what not. They quote to do the job.
I built an 8.5 X 3.5ish garage 3 years ago. Rough prices were:
I dug out the base and got the concrete poured, £800.
Hired a bricky to build it upto wall plate level with main door, side door and window lintels, he used block on 3 sides and brick on the front, £1600.
I did the roof with a mate, £700.
I got the side door and window off e-bay before we built it, £85.
Had a company in to fit a nice 40mm insulated, remote controlled main door £1200.
Then one of those small consumer units, 10mtrs of armoured cable, 4 strip lights and about 5 double sockets, maybe £250.
Probably some stuff I forgot about too.
Yours is obviously bigger with more span on the roof, but with a mix of trades and DIY you can save some money.
We are building a 10ftx18ft single garage. Single leaf blockwork.2.5m high with sloping metal roof. The windows/door will be from eBay. The garage will be rendered and front will be brickfaced at ends.
Dpc and concrete slab at 6inches
Foundation wall built 45-50cm
Excluding all doors windows the cost is £2500 for labour and materials. I have paid £1000 already .
Can upload pics as it develops . Concrete pour starts tmrw.
£2500 seems to be the magic number on your site, Adam..
It's seem like so but he quoted me £2700 for conversion and 2700 for garage. In the end we settled for £5000 all in (£2500 for both). It's not a magical number I will show you works pics. You have me worried now thinking he's gonna mess it up.
£5k for a new garage and a garage conversion?
YOU HAVE GOT TO BE HAVING A GIRAFFE!
Footings dig grab hire and machine hire.... 850
Conc for footings 9 cube ....... 1000
MOT stone for base and perimeter 9t ....... 260
Drains and soakaway etc .............. 600
Blocks x 1500 ..... 1600
Sand/cement ....... 350
Concrete and mesh for floor ............ 800
Lintels ....... 500
Wall plate, roof carcass, ancillaries........ 1400
UPVC door and window........ 700
Roof tiles, cloak, felt, lath etc...... 800
Gutter fascia..... 200
Garage door...... 1200
Render..... 1000
Electrics (including armoured cable and labour)..... 600
Scaffold..... 500
Total without labour...................................... £12'360
Very rough estimate so add another £1000 for variables and you are about half way there when you factor in labour on top.
Lintels ....... 500
Render..... 1000
Scaffold..... 500
Half of those costs we don't include
The trench was dug
without machine hire.
He has cement mixer hired.
Doors and windows not included
Received 4 ton ballast
25 bags concrete and 4 packs of blocks.
No eletrics and just metal roof
Lintels will be needed for door and window.
No soakway.
Gutters only
Render will be £200 he said at his cost.
No scaffold that's his decision.
No mesh
Pic of materials
The trench was dug
No soakway.
Gutters only
No mesh
My costing is for a legit structure not some Micky Mouse bodge built by a homeless Eastern European.
