It's quite common for repositioned meters (such as those lowered for health and safety reasons) to have only one neutral connection. The other terminal being fitted with a golf tee.
OK. What is a golf tee in this context?
Lowered into the flood zone, you mean?... such as those lowered for health and safety reasons ...
No, it measures volt-amps.Rubbish. The meter measures watts
It can measure current without a N connection. It can assume a supply voltage. It has no idea about phase angles.and needs to know current, voltage, and phase angle.
It doesn't.How can it determine voltage without a neutral connection?
It doesn't always, as many of us know.But the neutral connection always does pass through the meter.
It doesn't.
Sorry - it was a very badly worded post - I failed to use either ?s instead of .s to indicated possible mechanisms, or the word "could".This is the second misleading post from BAS that I have read today. This is not a good omen.
I think you've got your W vs VA the wrong way round...Domestic meters measure watts, only industrial meter measure VA, because as large users they have to be responsible for keeping their own PF low.
OOI, which was the other?This is the second misleading post from BAS that I have read today.
Actually I suspect that is not quite true. Phase angles assume pure sine waves. I suspect that the meters calculate a number of samples per mains cycle of instantaneous volt * amp measurements and add them together.This would be simpler and result in a wattage value. The current (and indeed voltage) waveform shape would then not matter. It could derive a notional phase angle from that, but there wouldn't be much point.They can determine phase angles as well otherwise they could not measure watts.
No - it will result in a sum of VA values.I suspect that the meters calculate a number of samples per mains cycle of instantaneous volt * amp measurements and add them together.This would be simpler and result in a wattage value.
Power?The electromechanical induction meter operates by counting the revolutions of a non-magnetic, but electrically conductive, metal disc which is made to rotate at a speed proportional to the power passing through the meter.
