precast concrete base for shed
13 Jul 2014
I have to demolish an old precast garage to allow for an extension. After giving thought to a few options I decided to go with a PvC shed. The shed requires 100mm thick concrete slab around 3000mm x 3000mm at the base.
Quotes received for preparing site and purring mixed concrete for this work ranged in the area of £700~900...o_O
I worth if worth considering a precast slab or something alternative for the base and whether it would save costs or have the opposite effect?
So a "precast " slab 3 metres square and 100mm thick?
How in God's name do you move that?
Paving slabs installed on a decent base will probably outlast the shed. 75mm of hardcore and 50mm of screed.
However it may be cheaper to simply pour a slab with readymix. I have done plenty and it usually works out similar cost but the concrete is better. If you need to shift materials a long way concrete is definately better.
There is a reason there is no market for precast concrete shed bases, its technically impractical and prohibitively expensive.
It is an option :p
But I have to do it right and cannot delay the rest of the project...
Make a frame from 4x1, pour the concrete, run a 4mtr length of wood along the top of the frame to level and its job done.
Stick some mesh in it if you like but I wouldn't bother.
R896neo is right about the ready mix, it would be quicker and cleaner and might even be cheaper than doing it yourself if you had to hire a mixer.
See the frame on this one?:
Ready mix is about £100/m3 depending on locality...........so for £100 (0.9m3) it just isn't worth messing around with a mixer, cement, aggregate, mess, hard work etc.... Some firms also offer chopped fibre addition to the mix, so may not require the steel mesh.
By ready mix I mean a volumetric mixer, not a drum mixer. You only pay for what is needed on the pour. Most firms will probably have a minimum call out fee though. Worth a call round the local firms.....
Great advice everyone, I can see why precast will not work and sounds like readymix is the way to go!
Seems that some a few companies will do 1m3 as a minimum, only thing is I need to figure out how to have this poured at the back of the garden...:rolleyes:
So you just mean a cast base, created in advance?
If you have side access it's easier.
If in a terrace you might have to wheel barrow it through the house so preparation would be the key with tarps and hardboard laid as protection
Barrow mix is where a truck with dry ingredients arrives and they mix on site.
Yes I have a side alley, thank god for this :)
