Good Evening
I was wondering if you could help me ?
I recently moved into a house which was built in 2013.
When I moved it the heating system was already dosed with Fernox Protector F1.
When I drained the system the water ran clear as expected. however when I removed the radiators from the wall and poured out the remaining water from the bottom of each radiator I found that it was dirty and rusty coloured ??
I let this water settle and found that the rust particles and dirt settled to the bottom - the water above was more or less clear.
Is this normal ?
Might the system have been under dosed ?
Should the system now be treated with Fernox Cleanser F3 before it is redosed with Fernox Protector F1 ?
Thanks in advance.
Is this normal ?
Thanks in advance.
