I need some advise for wiring 2 150W Security Lights, the way I intend to do this is run a 3 core cable from a switched fused (3 amp) box to the outside of the house, this is where I need the advise the 2 Security PIR Lights are identical and the wiring connections are the normal Neutral(N) Earth(E) Live(L)
With a L1 connection as well (This is the one that confused me !)
If I wire the first light as normal to the Neutral, Live and Earth, do I just tee into the Neutral, Live and Earth or do I use the L1 terminal to carry the live feed to the second light and then just tee into the Neutral and Earth.
And at the second Light wire to the Neutral(N) Earth(E) Live(L).
Hope this all makes sense
Thank you
Thank you
