Why does it seem to have an electrolytic water device in the left hand pipe which I would expect to be the CH flow?
It is obvious by looking at it that the two right hand pipes are the CH flow & return, the centre the gas pipe and the other two the cold water in and hot water out. The lever valve is the hot water outlet. The left had pipe is capped off. I like the idea of 22mm to the combi cold feed.That's a good idea.
And the device on the left hand pipe?
The left hand pipe is indeed is CH Flow and has a device known asThat's a good idea.
A £billion!!!!How much did it cost you in the end
I still used liquid inhibitors... the more protection the betterGot it wrong. The jury is out on the in-line salamander corrosion guard that replaces liquid inhibitor.
Absolutely correct Tony.It may be obvious to you!
But it is not what I deduced by looking at it.
Luckily the boiler MI also confirm that my assessment is correct and the left hand pipe is the heating flow!
I am not impressed by your abilities in this respect.
He is wrong on my abilities though. Let's face it you have had a few spankings from me.Absolutely correct Tony.
He is wrong on my abilities though. Let's face it you have had a few spankings from me.![]()
Are you referring to the suggestion you made regarding "weep tubes running all over the house from boiler to room stat"?..He is wrong on my abilities though. Let's face it you have had a few spankings from me.![]()
You have been told, you must stop making things up. Get a grip! With your leather straps I am sure you will take that another way.Your abilities are laughable.
He is still at itAre you referring to the suggestion you made regarding "weep tubes running all over the house from boiler to room stat"?....
The room stat would have been located within close proximity of boiler..
Stating the fill loop valve is positioned on the CH flow which in turn fills the system via the CH return is laughable.....that'll be another keyboard fooked..![]()
