masonry nails
18 Aug 2008
Devon
tried using some to secure some conduit for cables but they don't work in brickwork at all and just bend up. What is their intended use? and if they are not designed for brickwork why is this not specified? Brickwork is masonry is it not ?
If it's any consolation, I can't get away with them either......fine on thermalite or other soft blocks and on lime mortar but otherwise they either bend or snap off like bullets :eek:
Must be doing something wrong!
John :)
Elude me too. I either bend them slowly or explosively shatter them which is "exciting"
Waste of a few quid then, =/ at least I'm in the same boat as the rest of you at least
If you can knock em into a masonry joint then I have some success there, but not into brick. Anyhow our house is built of Accrington bricks which laugh in the face of many things, which is both reassuring and damn annoying.
now that cordless hammer drills are ubiquitous, I don't see much need for them.
Daft as this may sound, when I need to use a masoary nail, I drill a small pilot hole first.
Not daft at all Doggit - that's exactly how cast iron pipes with "ears" used to be nailed to walls. A pilot hole just smaller than the pipenail was made with a Rawlplug tool and hammer.;)
