- Joined
- 7 Nov 2017
- Messages
- 72
- Reaction score
- 0
- Country
I've just been reading a book titled "Central Heating" written by Patrick Mitchell. It's a really good book with lots of information I must say.
On page 48 and 49, an example is mentioned:
"the water in the mass storage tank is heated indirectly by hot water from the boiler passing through a heat exchanger at the bottom of the tank as is found in a conventional indirect hot water cylinder. The hot water for the taps is taken directly from the cold water mains supply and heated by passing it through a second heat exchanger external to the thermal store tank. This arrangement involves a fairly complex control and pumping system but has the advantage that lime bearing water from the mains is not heated to as high a temperature as the water in the tank. This avoids lime scale deposition inside the piping carrying mains water."
So, does anyone here have a such a thermal store? Is it any good? What are the pros and cons?
