Indeed. I wonder if it was 0.03 kΩ - i.e. 30Ω which, as winston has said, is about what one would expect of a working 2kW element.That's extremely unlikely.
A 48W element??Working, they would normally be around 1100 Ω ....
Fair enough (I was thinking that there were 3 x 2kW elements!), but I still can't see that EFLI's "1,100 Ω" could be remotely correct.There’s 3 elements in there. Total 2.55KW. so 850W per element
= 62Ω per element.
The XL18 has three separate elements. All of them all went open circuit at the same time? I cannot believe it.
Why can't you believe it? Quite apart from the fact that we know that it is true of the OP's heater, I thought that such an arrangement was very common (maybe even always the case) for storage heaters?I cannot believe there are three separate elements.
0 (zero) Ohms is not open circuit.
As EFLI has said, I think it's very unusual - as he says, it's normally something like "OL" or a "1" at the LHS of the display.It's what some DVMs show with an open circuit.
I think you and I should have Googled the actual model, quoted by the OP, earlier.Because his drawing shows four elements
TTC's drawing you mean? - if so, then yes, it does, but we (including TTC, who said so in the post to which you responded) know that the OP's one has three elements and, in any event, I thought that what you "could not believe" was that there were multiple separate elements (whether 3 or 4) - which, as I said, I thought was 'the norm' for storage heaters.Because his drawing shows four elements
Do you mean 'OL'?
It would be strange to show '0' (zero) for 'open' and '0'.
You're right - I was misremeberifying this: https://www.diynot.com/diy/threads/klima-ufh-mat-am-i-being-stupid-here.487217As EFLI has said, I think it's very unusual - as he says, it's normally something like "OL" or a "1" at the LHS of the display.
For each of the three? As you've been told, even that figure does not make much sense - they ought to be around 60Ω if OK, or 'infinity' (or near zero, but then something would have tripped or blown) if dead.After all your responses I have gone back and checked the resistance of the elements. Don' know how I managed to get the previous readings but the correct reading is 8.3ohms
