I agree, it had no bearing on the matter
I simply removed the transformer, connected brown to red, blue to blue, and earth to earth, went downstairs and switched the light on, and it all works as it should.
1. arsesCome on then smart arse's give a better explanation, if you dare???
Yes, but bernard was talking about a 'Variac', which is not what the OP has. As has been said, the OP has an auto-transformer (not a variable voltage transformer/'Variac'), which does not have an 'infinitely variable output'. In fact, in the OP's case, it has only one possible output, since the winding only has one tap.Really, thanks for the advice.
Indeed. You just beat me by a minute to making the same comment!You're now supplying 240V to something that was previously being supplied with only 120V. That's not always a good idea....
He was, and on this occasion there is no way he can deny itI agree, it sounds like he was talking balls.![]()
The neutral is connected to earth at the substation. So it stays more or less at earth potential, while the live goes more positive and more negative than earth.
You're very welcome.Thanks guys for correcting my incorrect use of ', as to be expected.
All you explained is why current has to flow in one conductor when it flows in the other. You could just as easily argued that the 'balls under pressure' were in the neutral pipe and the 'return path' in the line one.Come on then smart arse's give a better explanation, if you dare???
Ok, I give you a cable with 2 conductors in it, unmarked. You can measure 240 V a.c. across the 2 conductors.What an incredible easily understood explanation, bring it on>
Interesting name "echoes" ie no substance.You're very welcome.
