850 VA auto transformer - nice; Unless it was massively oversized, that would have lit something up well. Get it on eBay - might be worth a few quid to someone!
PS what dos the "auto" refer to?
It means the output voltage is infinitely variable,
It means the output voltage is infinitely variable, rather than fixed or a selection of voltage outputs that have to be individually hard wired. For for this reason they are considered unsafe.
With careful selection and installation they are safe
Not infinite, limited by the maximum and minimum of the device
The neutral is connected to earth at the substation. So it stays more or less at earth potential, while the live goes more positive and more negative than earth.
I'll have a go. Think of the LIVE as a pipe connected to a generator full of ball bearings ( one behind the other) at a pressure of 240volts that are waiting to be released one at a time, or 50 per second. The NEUTRAL pipe is full of balls whose energy has already been released. With no connection between the two ( switched OFF) nothing moves.
When you switch ON, you release one ball at a time onto a "water wheel", the wheel moves one revolution in a 50th of a sec, after the balls power has been used it must now return via the neutral to the generator to be recharged and to fill the gap left by the LIVE ball.
