Rewiring this light socket
31 Mar 2017
I forgot to take a photo before pulling it through the wall. Annoyingly.
This is a two-switch socket (upstairs/downstairs lighting). So the cable coming from the top is no problem as that's the ceiling for the top floor. It's the two coming from the bottom that I'm a bit confused with.
I assume one goes to the switch downstairs, which would make sense as it's 3 core+e. But what about the other one? I assumed there's be a 2 core+e going to the downstairs lights but I guess that doesn't happen. Does it go to a junction box somewhere? If so I haven't been able to find it. Although I don't have access under any floor.
Anyway, can anyone please shed some light on how this should be wired back into a 2-switch socket?
Is there a two way switch for the upstairs light? I would guess one of the 3C&E is actually for the same light controlled by the T&E but we need more info.
With new switches labelled Com L1 and L2, cable to left will go to L1 and L2 on one of the switches, the other two cables need wiring same as other end, so open up the other two way switch at other end of cable and wire like for like.
The problem is working out which three core and earth is which, I would temporary fit a junction block on the two core and earth cable, and wire the three core and earth to match other end, find out which switch does not work, then add the two core and earth to the switch which does not work.
Circuit diagram of two way switching so you can see what you are doing, I am assuming both switches were two way?
So now you are going to have to find out what they all are.
Basically you're going to have to choose between Plan A and Plan B.
PLAN A:
PLAN B:
  • Get an electrician.
There are some irresponsible people here who will tell you that there is a Plan C, which is to start trying different things without really knowing what's going on, hoping to get it working by luck, or by blindly following instructions to put-this-wire-in-that-hole without any idea as to why. Please don't listen to them - you must know what, and truly understand what, you are doing.
Electrical-installation-by-guesswork is a foolish idea.
There is no Plan C for anybody sensible.
