Tiling bathroom
19 Nov 2008
Dorset
Just about to lay 2.5mm vinyl tiles in the bathroom over plywood. Do I need to seal the plywood before gluing?
I've got to cut round a quadrant shower enclosure. I have a few ideas how to markst it, but is there a normal technique for marking round things?
Cheers, Camerart.
no ned to seal the ply.
cut out some same size as the tiles stiff paper an after tiling up to the enclosure make templates for each vinyltile. eg if the vinyl is 300mm x 300mm then paper templates at 300mm x 300mm.
theres pro methods for scribing but i cant explain them on here
Hi B,
Good stuff, much appreciated, I should be able to do it now.
No need to give trade secrets, I understand.
Thanks.
C.
camerart, no mate, i mean its too complicated without pics of some kind. i'm not up to keeping trade secrets. but glad it helps
Hi B,
Overnight I kind of worked something out with a square and sliding 'following stick' to copy the curve as it moves round. You definately need picture to explain it:)
Thanks.
C.
