Do you think that you could (without measuring) confidently distinguish between 20mm S/S conduit and 22mm S/S pipe?
I think so, the saddles, clips, fittings, sound when you tap it, may assist as well.
Possibly, but I'm not convinced. Apart from anything else, you're assuming that the 'appropriate saddles etc. will have been used.I think so, the saddles, clips, fittings, sound when you tap it, may assist as well.
If you're referring to the most recent discussion, that was about stainless steel pipe. I don't even know whether that is ever used for gas, but I doubt that many people would pay a premium for it and then paint it.The biggest give away is that many steel gas pipes are not bare. Galv conduit is obviously bare, but steel pipe used for gaswork is often (but obviously not always) painted a reddy brown or yellow plastic coated
Yea my post was of course referring to steel pipework, not SS foolishly.If you're referring to the most recent discussion, that was about stainless steel pipe. I don't even know whether that is ever used for gas, but I doubt that many people would pay a premium for it and then paint it.
However, what do you think about my general point, that I think all this talk about 'what pipes {or whatever} look like' is really a bit unnecessary, since no sane person should be cutting into the middle of any pipe/tube/conduit/whatever without first making very sure that they know what it is connected to (gas appliance, bathroom tap or electrical accessory!)??
Up to a point, but should even a plumber really be cutting into the middle of a pipe without having ascertained 'where it goes' and 'what it's connected to'?Well, if you're a plumber and you've turned off the gas & water then I think it's fair game to be cutting into any pipework
Or an electrician vice-versa.I'm not sure that one could rely on all plumbers being able to confidently distinguish between microbore pipe any pyro of a similar size.
2H16 MICC looks like a copper tube with an OD of 14.7mm.Do you think that you could (without measuring) confidently distinguish between 20mm S/S conduit and 22mm S/S pipe?
Indeed - we are both pointing out that size (even if actually measured) is not a reliable guide to what's inside.Up to a point, but should even a plumber really be cutting into the middle of a pipe without having ascertained 'where it goes' and 'what it's connected to'?
In my house as, I imagine, many others, my gas (LPG) and water pipes look identical (copper), and in quite a few places run alongside one another - and one would hope that a plumber wouldn't use a 'trial and error' method to ascertain which they needed to cut into! They would surely follow them until they came to something that made it clear what the pipe was carrying - and if, to their surprise, (and a bit back-on-topic!) it terminated in an electrical accessory, that might give them a clue that it was probably not carrying either gas or water![]()
That doesn't surprise me, and I see no problem with it, particularly if it was (as I imagine) obvious that it was 'connected to' an electrical socket.Years ago we used to drop down from ceilings to sockets with standard electrical 20 mm plastic pipe and threaded adaptors, we would oversleeve the assembly with the chrome pole that you get from likes of B+Q and the adaptors held it secure though you could rotate it, in our case it was in the middle of a shop floor and im not sure of any suitable wall saddles to match
