Keep digging - I'm sure you can unearth more evidence that I'm the one not reading and understanding properly.That's exactly what I said I couldn't, and wouldn't, do ....
My 'rest' therefore calls me back.
An experiment to see what would happen if you decided I must have meant something idiotic and decided to therefore falsely claim that "You don't seem to have done very well tonight at reading and understanding previous posts in the thread"?OK - experiment over.
But you'd have had no need to turn it any more, as I'm assuming that if you used a spanner you'd not chew up the fitting?
it 'self-tapped' it's way so firmly into the 20mm knockout that I couldn't turn it any more to hide that mess from the camera
If you're going to behave the way you have here, that's probably best.My 'rest' therefore calls me back.
On top of that, you would struggle like crap to make the tube off into the socket. And you’d need to Earth it
Thanks. However, I'm not going anywhere - merely reverting to being a little selective about whose posts I respond to!All the best John. Hope to see around again soon.
Although I confess that I have always religiously earthed it (when putting T+E or insulated+sheathed flex inside it), I'm not at all convinced that there is any such requirement. After all, it is acceptable for people to touch such cables, and there is no general requirement to earth metal which is in contact with the sheath of such a cable.Do you need to earth it?
Good to see you. Happy New Year!Seriously. Out of 4 pages in a thread in Electrics UK, 3 are discussing how you can use plumbing materials to install a circuit. Wonder why manufacturers bother to make conduit (to the relevant BS) or the correct cable to use as required.
I'm with you on this one. MICC if you want the copper lookHappy New Year.
I saw the original question but don't get why anybody would go down the route discussed here. Copper pipe and compression fittings are used by plumbers. Electricians use conduit and conduit fittings.
I essentially agree - as you will see, in the very first response to the OP's question, I suggested steel conduit.I saw the original question but don't get why anybody would go down the route discussed here. Copper pipe and compression fittings are used by plumbers. Electricians use conduit and conduit fittings.
Whilst it is true that copper pipe and fittings are usually used by plumbers, that, in itself, does not mean that it cannot be used for for essentially decorative purposes in order to improve the aesthetics of surface cables - in just the same that wood and wood fixings are usually used by carpenters/joiners, but can be used to improve aesthetics by 'boxing in' cables.
Very expensive to have done.I'm with you on this one. MICC if you want the copper look
