Indeed. However, as you will have seen the OP has another theory ....TBF, some enclosures have "TOP" moulded into them, but it appears on opposite sides of the enclosure (in other words, it can be mounted either way up).
.... I spotted that its upside down but assume it was to allow the sensor some light and away from a close wall?
Not sure how that is relevant. It would be, were the problem reconnecting the old light after removing it for painting the wall, for example, but it's not.I think something is still amiss with the wiring as others have said. Can you take a picture of the label on the black box in the old light? The original wiring doesn't suggest the two brown cores should be connected together.
Are we sure about this?Did you change the two sensitivity screws, the left one for how dark the night is when the PIR actually starts to operate, and one for how long the light stays on. Turn them both anticlockwise (comes on when very dark, and stays on short time) and try again.
No - that's a different light, his is a 162469316, you've linked to the manual for a 162468786. The instructions for that (such as they are) bear the product code 16246/**/16 - chances are that the ** covers the different colour variants, and that a 16246/**/16 & 16246/**/86 are functionally different.
Do I take it from the above that you actually did find two controls to turn and, if so, were they marked similarly to those in the instructions we've been talking about?... I've just rewired it now and turned the controls anticlockwise so will give it 15mins and see if it works.
