Needing some advice for installing these lights safely, they are deemed as double insulated, but only if the supplied enclosed connection box and its sheathing are used and feed to the wiring connections outside of the fittings rose.
the pendants have a metal rose that attaches by 2 screws to the metal ceiling bracket, the pendant is hung on a metal chain and the light itself is metal with glass framing
http://www.lauraashley.com/uk/ceili...-brass-glass-frame-pendant-light/invt/3650506
There was no space for a terminations to be fed up into the ceiling so I installed them using wago lever lock connectors instead of the supplied connection box, and the wago's are now sited within the metal rose.
From what I can see, the light is now not double insulated, so in a fault condition the metal rose and frame could become live as there is no termination on the rose for an earth.
Has anyone experience of similar installs, and what is the best work around to make them safe. Lots of confusing answers around the web!
Only things I can think of is earthing the rose and metal ceiling bracket (but this could cause further dangers) or digging space in the plaster above the rose and locating all connectors outside of the metal rose and using the rubbish connector box and sheath provided
Read more: https://www.diynot.com/diy/threads/...-ceiling-pendant-lights.497028/#ixzz56AooKJxs
