Then the MI's will stipulate.
It's common sense, set down in writing for those who don't have any! After all, a 13A fuse wouldn't give much protection for a circuit drawing less than an amp!Is it written in Gas Regs, or just manufacturer's recommendations?
Actually it's anything but, which is why this discussion is taking place.It's common sense
A circuit drawing less than an amp will draw less than an amp no mater what the fuse rating.a 13A fuse wouldn't give much protection for a circuit drawing less than an amp!
A table lamp cannot overload the flex, the only overcurrent that can arise would be from a fault, so as long as the 13A fuse can protect the flex from a fault it is the correct fuse. The rating needed has nothing to do with the bulb, and everything to do with the flex.You must have come across table lamps with 60W bulbs fitted with a 13A fuse because the owner thought that was the correct fuse -"It's a 13A socket, so it must have a 13A fuse".
No they won't, and no it won't.Now that low wattage LED lighting is more readily available, the experts will have to rethink plug fuses. Even a 500mA may be too large.
How many table lamps are supplied with a cable capable of carrying a continuous current of 13A?A table lamp cannot overload the flex, the only overcurrent that can arise would be from a fault, so as long as the 13A fuse can protect the flex from a fault it is the correct fuse. The rating needed has nothing to do with the bulb, and everything to do with the flex.
How many table lamps are supplied with, or later fitted with, 3kW bulbs?How many table lamps are supplied with a cable capable of carrying a continuous current of 13A?
You are missing the point.How many table lamps are supplied with, or later fitted with, 3kW bulbs?
Yes, against faults, not overloads.As you said, the fuse is there to protect the cable.
This appears to be the current understanding:
- There are no requirements in the Wiring Regulations for gas appliance supplies to be fused at 3A.
- There are no requirements in any gas regulations for gas appliance supplies to be fused at 3A.
- The Wiring Regulations do not make it mandatory to abide by any manufacturer instructions.
- The Gas Safety (Installation and Use) Regulations (I'm assuming it is they) do make it mandatory to abide by any manufacturer instructions.
- Some gas appliance manufacturers require 3A fusing in the UK.
- Some gas appliance manufacturers do not require 3A fusing outside the UK.
- Nobody knows why #5 is justified, particularly when #6 applies to the same appliance sold elsewhere.
- Notwithstanding #7, #4 means that observing #5 is not optional.
If that is correct, why are table lamps now fitted with 3A fuses as standard?So as long as a 13A fuse will do that to the flex then the flex does not have to be rated at 13A.
That is the point of the discussion.If that is correct, why are table lamps now fitted with 3A fuses as standard?
...which over-ride gas regulations
