I do not think that any opacity was on your side...It doesn't seem like my night for clarity![]()
So, your suggestion is, what?
Fair enough, that's a perfectly reasonable way to do it.Ok thanks John, i have to go with winston, i always test the outputs with a lamp on a spare lamp on a lampholder lead.
Indeed. As I've just said, if one has to go up a ladder with a meter to check that, if one finds that 230V is present one might as well then try to use the same meter to see if anything is coming out of the secondary - and, as I've said, I would be very surprised if any multimeter failed to show any secondary voltage (if secondary voltage was there), even if it were 'high frequency' AC.Checking there is 230VOLTS on the Primary must be the first step, before we get oscilloscopes out of the loft.
Oh dear. I got shamed for making that suggestion.Checking there is 230VOLTS on the Primary must be the first step, before we get oscilloscopes out of the loft.
Don't worry - one can get shamed for almost anything around hereOh dear. I got shamed for making that suggestion.
Sorry, I must have missed it.Oh dear. I got shamed for making that suggestion.
Well, we all know what they say about assumptions, but...Sorry, I must have missed it.
But I don’t know if the OP has checked this, or even has the ability to do so.
I’ve .. re-wired a standard pendent fitting in its place as a temporary stop gap until I manage to fix or replace the chandelier.
