exactly so lets ban the US president visiting the UK , after all Europe does not need the USA to back it up![]()
well thank goodness the USA is in NATO, otherwise were are like lions whith no teeth.
You are putting words down that I never said.i’m confused. You’re saying her current course of action is right a week after the attack but also doing nothing for 4 years was also right for her predecessors?
You’re also saying that she did nothing despite taking an active roll in insuring the findings were published from the last time.
It seems whatever she does or doesn’t do is going to be wrong. Is that your position summarised?
Dream away, troll, gently down the stream.What you implied is that TM was PM at time of Litvinenko case
You are in such a tizzy you forget where you are coming from.
Thus you have no idea where you are going or how to get there.
In essence, you are lost.![]()
The French actually mounted an air raid on Gibralter against the British in WW2 , when they sent there bombers to bomb the british naval base.
By all means, provide this evidence.What you implied is that TM was PM at time of Litvinenko
true, that would of been better for both, but they said they will scuttle the ships before the germans got hold of them, we did not trust that. so over one thousand French sailers lost there lives.
and there was another port,the french had 70 or so ships, they scuttled them before the germans got there.
I know you cannot, you know you cannot, so you resort to your usually trolling behaviour.
Hint: It was a labour government in 2006.![]()
But you, nor notch, can find it.The evidence is there for all to see way r bee
So you continue to make baseless allegations.
It is what you do.
It is what you are.
Then the usual abusive drivel
Post number 33 reproduced for you:You said:
And who was the home secretary then: PM (IE TM).
see your post no 33 at 6.35pm 13/3![]()
And who was the Home Secretary then?
I was referring to the inquiry date, not the date of the criminal act.
Then go find it, instead of claiming that you can.of course i can find it
Bats in the belfry, probably.yes way r bee transam has contacts in high places do not ask for whom the bell tolls way r bee it tolls for th**
In case you can still not get your head around it, it is impossible for the incumbent PM to also be the incumbent Home Secretary at the same time.
Numbskull!
