- Joined
- 11 Jan 2004
- Messages
- 46,883
- Reaction score
- 3,987
- Country
I had the same thought. Counting and measuring the strands in the conductor would tell you.
I don't think that counting would help, since 7/0.029", 7/0.036" and 7/0.85mm (4mm²) all have 7 strands - but measuring the strands would obviously do it.I had the same thought. Counting and measuring the strands in the conductor would tell you.
Very true - but, given the external dimension the OP has told us, it would seem unlikely that it's 3/0.036, wouldn't it?Well, if the cable was 3/0.036, it would be obvious.
Indeed. I don't know whether we are actually sure that it is Imperial. If it were, like you, I don't know what the dimensions would be, but 4.2mm OD would seem very large for a single-insulated ~1.5mm² conductor. Anyway, this is all speculation - if the OP is able to measure (and count) the strands, we will get an answer.As it is imperial and insulation was often thicker, I don't know what the measurements would be.
Every Electrician knows that it is mandatory for live conductors to enter ferromagnetic enclosures together (unfortunately fewer understand that the cpc or Earthing conductor also MUST. How on earth (excuse the pun) were you not aware of this? Are you competent to be carrying out electrical work? Do you want a reading list?However...
And that does say they have to go through the same hole. I wasn't sure if the regs said that, or if (as they could well have done) they only required conductors to be arranged to avoid problems of electromagnetic heating.
So there's another thing your bungling soi-disant electrician bungled.
Fortunately, as we know, the currents in your cables will never be high enough to cause any significant heating.
That latter bit ("MUST") may be theoretically true, but if the installation were such that a sufficiently high current could flow in a CPC or Earthing conductor for a sufficiently long time that there would be significant heating effects if it did not pass through the same hole as the live conductors, I think one would probably have a lot more to worry about than which conductors were passing through which hole.Every Electrician knows that it is mandatory for live conductors to enter ferromagnetic enclosures together (unfortunately fewer understand that the cpc or Earthing conductor also MUST.
I'm not quite sure how that would/could arise. Any final circuit will (should!) have its own CPC - either within a T+E cable(s) or as a separate conductor if wiring is in singles. What situation did you have in mind?And what happens when you have multiple circuits but only one cpc.
Dunno - I've never wired in singles - so you'd have to ask someone else. However, if one did as you suggest, one presumably could not, for example, test the continuity of the CPC in a ring final circuit.I didn't think you needed multiple cpcs if wiring in singles, just one large enough for the largest circuit carried.
