EICR - please advise
In fact I noticed quite a few errors in ericmark's post, but I simply couldn't be bothered going through it bit by bit.
Why is it very obvious? And it could well be 15A.
Well, I would say that it's fairly obvious (from context) that it was meant to be a (numerical) current - but whether 15A or 16A is less certain. 15A would be more easily misread as "ISA", but I very much doubt that they are 15A MCBs!
Could it be two radials?
It wouldn't surprise me. It seems that a good few 'electricians' (not to mention a substantial proportion of the general public - some of whom believe the same of lighting circuits) don't realise that a sockets circuit doesn't have to be a ring final!
My ideal setup for my 3 bed semi would be
Upstairs socket radial (20A)
Downstairs socket radial (20A)
Kitchen ring (32A)
(plus of course radials for lighting etc).
Kitchen ring (32A)
It's not usual to use a 20A radial for an entire floor. Typically each 20A radial serves two rooms. (Or if used in a kitchen it only serves half of the socket outlets, with a second 20A radial for the rest.)
Downstairs is actually only two rooms, apart from a couple of singles in the hallway. Granted in a bigger house you'd probably want more individual circuits.
True, I hadn't thought of that - but were they still being installed in the 80s?
As I stated earlier, it is possible that they are 15A but more likely that they are 16A. (Which could still be read as "ISA" if the curve is missing from the bottom left of the "6" - whether a printer ink issue or pen ink issue.)
My ideal setup for my 3 bed semi would be ... Upstairs socket radial (20A) ... Downstairs socket radial (20A)
I'm certainly no opponent of radials, but I'm less 'happy' with multi-socket 20A ones - after all, one technically can overload it with just two 13A loads (or three 7A ones). It's not so much that I fear the OPD would operate (a B32 should take best part of an hour to trip at 32A, and sustained 'overloads' would be unlikely), but rather that I would prefer not to risk pushing MCBs beyond their rated current.
32A radials are fine, and, give or take CPC redundancy, are often arguably preferable to rings. ... but all this is obviously 'personal opinion'.
There's nothing wrong with 20A radials, but as I suggested it's more sensible to only serve a couple of rooms with each (or half a kitchen).
Personally, for a house, I still prefer ring final circuits where they make sense. Where they are pointless I will opt for radial final circuits.
As I said, it's just a matter of personal opinion.
I would personally only ever use 20A radials to supply rooms/areas where I believed that 'large loads' were fairly unlikely. A circuit with multiple double sockets which can theoretically only support about 1.5 'fully-loaded' 13A outlets just feels a bit 'tight' to me.
