Hi
I am about to buy a 2010 Corsa 1.2 16V Energy 3 door from the local Vauxhall Dealership. They have just MOT'd it last week and are awaiting a couple of parts for it before I take delivery of it.
When I looked up the MOT history I was pretty worried to see :-
August 15th 2018 :-
Pass
No advisories
August 14th 2018 :-
Fail :-
Do not drive until repaired (dangerous defects):
Front Sub-frame has excessive corrosion which adversely affects braking or steering (6.1.1 (c) (ii))
February 7th 2018 :-
Pass :-
with Advisory notice item(s) :
Front Sub-frame corroded but not seriously weakened (2.4.G.1)
February 6th 2018 :-
Fail :-
Reason(s) for failure :
Nearside Front Sub-frame corroded and seriously weakened at lower arm fixing (2.4.G.1)
ie 6 months after a sub frame repair in February it had a serious defect again.
Although they appear to have repaired it, I am wondering if this could be a sign of big problems in the future with this car due to rust.
It also had these faults in addition to the sub frame problem :-
August 14th 2018 :-
Fail :-
Repair immediately (major defects):
Nearside Front Suspension arm pin or bush excessively worn (5.3.4 (a) (i))
Monitor and repair if necessary (advisories):
Front Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
Offside Front Suspension arm pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
Fail :-
Nearside Front coil spring broken (2.4.C.1a)
Nearside Track rod end ball joint has excessive play (2.2.B.1f)
Has anybody had experience of these kinds of problems with Corsas of this age group ?
The Vauxhall Dealership has quite a good reputation so I am hoping they wouldn't sell me a bad car. However the warranty they give me is only for 60 days.
I have only put a deposit down, so I am considering asking to cancel the purchase based on this defect that has emerged after the agreement was signed.
August 15th 2018 :-
Pass
No advisories
August 14th 2018 :-
Fail :-
Pass :-
Fail :-
August 14th 2018 :-
Fail :-
Fail :-
