It is, because the light switch works on the permanant live connection.If you put the perm live into the switched live terminal, then the on/off state of the light switch is no longer relevant
True, in the sense that (if nothing is connected to the L terminal of the fan) the fan will never work, no matter what the state of the switch. For the fan to work, there has to be electricity supplied to the 'L' terminal of the fan.If you put the perm live into the switched live terminal, then the on/off state of the light switch is no longer relevant ...
I don't know if they are made like this but if it had integral PIR and humidistat perhaps it didnt have a timer and only had one L connection.I was pretty sure that when I installed my humidistat and PIR fan, I only connected it to the switched live, and ignored the live terminal. The fan runs off the mains ring via a fused RCD rather than the light switch.
That's true - until switched off.Surely if I had bridged the live and switched live connectors, the fan would never stop.
I wondered that since, as you imply, if it had just a PIR and humidistat (but no timer) then it wouldn't need a switched live (only a permanent live). However, I decided that this was unlikley, because we had been told ...I don't know if they are made like this but if it had integral PIR and humidistat perhaps it didnt have a timer and only had one L connection.
... which surely means that one of the conductors must have been a switched live (and, presumably, that a permanent L was also present, and connected to the other fan terminal)....Wiring the live to the T causes the fan to switch on and off with the light ..
Ah, I'd not noticed the change in discussant and fan - apologies!No, I was responding to Opps about his fan.
Maybe, but if it had no switched live connected to it, it obviously could not display the normal sort of timer functionality (over-run for a set period of time after light turned off), since it couldn't know when the light was turned off!I am pretty sure that it had a total of three terminals and that I ignored the switched live (because there was no switched live). Timer over run, yeah it has one. There are only two adjustable knobs the time and humidity level. It is an Icon 60 with the hm and PIR module.
Ah. That's different than what you said before.I am pretty sure that it had a total of three terminals and that I ignored the switched live (because there was no switched live).
It would work with just the permanent live connected as the PIR and humidistat just trigger the timing device internally - as they work without the switched live, i.e. when the light is not on.I was pretty sure that when I installed my humidistat and PIR fan, I only connected it to the switched live, and ignored the live terminal.
