Pyronix Euro 46 v10 Zone wiring
7 Aug 2018
Hi All
I currenlty have a old Euro Mini panel and looking to upgrade to the Euro-46 v10 so i can have a mixture of old wired PIR and new Wireless tech.
My question is looked in side the panel and the Zone wiring is different what the best way to install the old PIR back to the new panel the current setup did not have resistors on them
So far i have the panel powered up and connected the WIFI moudle and a Zem for the Wireless devices just stuck on the PIR wiring
And next question is as zone 1 and 9 are on the way out what the best option for FX/entry or Entry FX, timed or final set
ZONE 1 PIR is in the entrance on the way
ZONE 2 PIR Kitchen
ZONE 3 PIR Landing
ZONE 9 Wireless door contact
If your old set up used 4 wire , wire all 4 into each zone ( disconnect the old series up tampers and wire each pair to the zone tamper,
Exit zone should be 07 final exit , will have to be timed if it's a pir
Thanks do i need to change anything in the programming for the zones like the Resistors values or leave default settings
So make Zone 1 timed exit/entry and Zone 9 final set not timed as this is the door contact
Sorry didn't see zone 9 ....if that's the entry exit door set at final exit , the entrance can be entry route or ex/Fx if it's the first detector when you come downstairs , this will start your timer in part set
