oh my word, looks like it will kick off again if that's the case, but to make some of you rest a little easier, if your panel was bought as version 4 off the shelf then any built in wireless expander should be versions 3.0.6+
Separate panels and expanders would have to check the expander green sticker or in ricochet monitor to confirm the version of the expander.
If you have version 3 panels as supplied or earlier then you need to check the wireless expanders version number.
I will try and explain some of this based on my understanding.
The newer expanders have additional features so certain devices will work but maybe not fully ie some options won't work.
The statement you make regarding the hub, not working sounds as of it wouldn't work at all, with existing expanders below version 3.0.6 which would be ludicrous, I would need to clarify but suspect the new devices wouldn't work with the hub if the expander was below 3.0.6 but the old ones still will
The reasons why I say again, is because during the process of these transitions people were advised one particular way and it would appear that doesn't hold water, tbh I will check with with someone in tech that I trust to give an honest full answer and let you know.
How many hard wired devices do you have?
Thinking you might be better getting a 64W new panel rather than a new 8XPW or 32XPW and flogging the panel on ebay with updated firmware???
