- Joined
- 27 Oct 2018
- Messages
- 9
- Reaction score
- 0
- Country
Hi
I've got a Greenstar RI boiler, hot water cylinder in the airing cupboard, separate frost stat and pipe stat. The issue I'm having is that, i believe, the frost protection is very very frequently running the boiler, ( and central heating pump) throughout the day and night.
The frost stat is set below 5 deg, the pipe sat is set at the very minimum and yet the system kicks in frequently. Is this set correctly? The frost stat had a definitive click when turning it which makes me assume it works.
The pipe stat is set to the minimum but right now, despite the pipe being warm, as soon as i move it, even 1mm around, it starts the boiler. I've read that this should be set to about 20 deg, could this be faulty? I understand the Greenstar boiler also has built in frost protection?
The other issue, which I think is probably the root of everything, is that as you can see, the boiler is in a tiny garage room with wood doors and is very cold. I can probably do a little to insulate the room but with the wood doors I'm not sure how much good it will do.
Would anyone have any suggestions how to stop the boiler coming on frequently, the house rarely feels cold and the timer is only set for an hour in the morning, an hour early evening and 2 hours later in the evening. The water only comes on for 2 hrs in the evening. It's costing me about £2.50 a day in gas! Any help or suggestions regarding possibly faulty items, incorrectly wired in, incorrect set anything, or anything else would be much appreciated!
