Has anyone changed the Honeywell zone valve complete head yet?
Just asking
They're Draytons
Just asking
Hi Picasso. I want a full explanation of what the fault is - it’s quite clearly not the components - but a darn wiring live feed fault somewhere. Surely 4 Drayton actuators can’t be faulty? They’re only lasting 48 hours before the fault starts again. If electric wasn’t so damn dangerous, I’d have a dabble myself. I’ve learnt so much about S plan heating systems over the past few weeks, I swear I would now qualify as a BG apprentice. ...Please don't let him sort it out without an explanation of what the fault is.
Started off with a Honeywell and a drayton.They're Draytons![]()
Yes - that’s right Picasso. Started with Drayton actuator za6 heating side and Honeywell on water side.Started off with a Honeywell and a drayton.
So they just swapped the components without bothering to check if the wiring was correct????!!!!Hi Shambolic, thank you for your post - for both the new room stat and new programmer, BG literally ‘snapped’ off the front faces and snapped the new ones onto the existing back plates - no wiring was touched (replaced with exactly the same models)
Yes...had a quick skimmed look at the wiring and snapped them onSo they just swapped the components without bothering to check if the wiring was correct????!!!!
Got to admit I have not read through the 6 pages of posts but one possible fault is when using two valve set ups it is essential the feed to the micro switch is a permanent live. People do try using a feed from the switched live to save running an extra wire.
This results in both valves working ok seperatly but when both are on and one closes it can keep the other on. Cutting all power and turning on will clear the fault till the next time the same condition arises worth a
Strange one.
If wiring issue, why would it be ok for a day or two before faulting?Yes - that’s what I can’t get my head around? It runs perfectly for a couple of days and then resorts back to the original faultStrange one.
I agree with you 110%. I can’t wait to find out what the fault is and share it with you all.Reading through this thread, the time has now come to step back and start again, lots of kit has been changed to no avail in the hope of fixing this problem. Someone needs to take a look at this system and start from scratch, checking wiring is correct and the individual components that make up the system all work as they should. It will be something silly
Pretty well sums it up, on a personal note I would not mix different makes of valve on the same system from choice.If it is a lock up condotop due to mis-wired valve actuators it may only lock up when the micro switch in valve A operates before the micro switch in valve B operates. and not lock up if the micro switch in valve B operates before micro switch in valve A.
Timer . thermostats and rotation speed of the valves will affect which valve is the first to operates its micro switch.
I’m on about when they rewired the actuators.Hi Shambolic, thank you for your post - for both the new room stat and new programmer, BG literally ‘snapped’ off the front faces and snapped the new ones onto the existing back plates - no wiring was touched (replaced with exactly the same models)
