Hi guys, first post so go easy!
I have installed a Hive active heating and hot water on to the above boiler (before anyone says anything, the boiler was present when I moved to this address) and the demand for hot water works fine but the demand for the central heating does not.
So, the green light for the heating triggers and there is a click from the receiver to indicate a trigger has been sent to the boiler but the heating never comes on. I spoke to British Gas several times and they keep saying there is a fault with the boiler.
Anyone familiar with the above boiler will know there is an internal programmer built into the boiler and if I revert back to this both the hot water and central heating work fine so I know there is no issue with the boiler.
I desperately want to get the hive unit working with this boiler as I have been a Hive user at a previous property of a number of years and I can't really do without it.
I followed the below guild so I know it is possible.....
https://www.tapatalk.com/groups/britishgashive/help-wiring-hive-to-potterton-powermax-he-t330.html
Has anyone got any ideas?
Thanks,
Lloyd
Thanks,
Lloyd
