Don't let the door hit your arse on the way out. FFS. Illiterate fool.
Your arrogance is breathtaking. Even when you're clearly wrong your response is to ignore it and issue more abuse.Don't let the door hit your arse on the way out. FFS. Illiterate fool.
with various posters
Even when it's about something with no right or wrong answer
I don't suppose I'm alone in getting tired of these bully-boy tactics
Well, there's not going to be one definite answer to pressure loss, there are several ways to do it, and they won't give exactly the same answer. But what was your estimate? You didn't give one. As usual, you didn't say anything anybody could comment on, just your trademark abuse.Like your understanding of gas flow?![]()
Pointing out your mistake wasn't contributing then? Of course you prefer to ignore that.You're certainly not actually contributing anything as per usual.
I guess mine are as big as yours. At least I'm man enough to admit it if I get something wrong.Probably not, but your life would be happier if you grew a pair.
OK you clearly suffer from last-worditis. You can have it, I doubt it will be constructive.I thought you were out of this?
What bernardgreen was getting at I think (bernard, correct me if I'm wrong) is that 60kWh is a measure of energy, not power.
So you think the grown-up approach is to make no mention of the mistake, let alone acknowledge it? Most would just say yes OK, and that would be the end of it. But he changes the subject and tells me I don't know what I'm talking about, though he has no more knowledge about my competence than I do about his. Apart from power and energy units, where I know more than he does. With the usual name-calling thrown in. If that isn't kindergarten stuff I don't know what is. Oh and it's kW, not kw.So if Dan wrote “60kw” you wouldn’t be acting like a petulant child ?
