I'm soon to fit a new kitchen. The ring main is staying with a little bit of adjustment to a couple of socket positions. The lighting and the cooker hood fused connection will also be unaffected. The hob will be gas.
I'm having the existing electric double oven replaced with two separate single Neff electric ovens. The existing oven is supplied by a 32amp MCB at the consumer unit, 6mm T & E and a single 45 amp cooker switch.
The new ovens https://www.neff-home.com/uk/productlist/ovens-compact-ovens/ovens/single-ovens/B5ACM7HN0B are rated 13 amps. Would I be looking at getting another 45 amp cooker switch or getting the existing one replaced by two 13 amp switch fused connection units. I need to chase for any additional fittings prior to getting any electrical work done. Also would the 32 amp MCB remain or should it be changed for something else?
