Neighbour seen me playing around with a mower & dropped theirs in for me to take a look for them.
They went to purchase this mower where the seller started it to show it works etc. Get it home & they are unable to start it.
Plug has a spare but I noticed a hold in the middle of the primer bulb. I thought straight away that was the issue but looking online to buy a replacement I see the sellers text mention This Is The Type Without A Hole ???
Around the bulb is a red plastic cylindrical cap.
I’ve removed that a then you need to use a screwdriver each side to the release the plastic clip that holds the bulb in place.
Can you advise anything about the mention of the hole ?
I removed air filter housing etc & pressing the bulb NO fuel is seen squirting across when I look down into the carb.
I removed spark plug & give it a squirt of WD40 in the plug hole thinking it would then start but it never. It did sound like it wanted to though.
