Probably advisory. I recall a boiler (only a boiler off the meter nothing else) had a working pressure just below the makers spec'. We broke the seal on the meter regulator opening the regulator slightly until the minimum mb at the boiler, plus a bit more. It worked. Transco men (at the time) didn't care a hoot if the seal was broken.
All I'm saying is - those readings aren't due to differences in boiler design, only to reduced gas flow or maybe higher pressure at the meter (which would be dishonest, to put it mildly).
Fixitflav & hard-work clearly show their incompetence when discussing gas related topics.
The YouTube video clearly shows the manometer measuring the gas burner pressure and not gas working/inlet pressure on the Potterton Profile boiler.
The 3 bods in that video are a bunch of clowns (I personally know them) as is fixitflav and hard-work.
The new boiler works very differently, that point he was emphasising. I assume a negative pressure gas valve of some description to draw the gas through the pipe from the meter.
The working principle of the zero/1:1 governor does NOT “draw the gas through the pipe” as stated above.
Fan pressure whether negative or positive acts upon a diaphragm (offset) and in turn regulates the volume of gas to burner/mixing chamber by bleeding-off pressure to the underside of working pressure diaphragm.
It clearly wasn’t “working pressure” but “burner pressure” that they were measuring on that Potterton Profile.
The inlet/working pressure on that Potterton Profile would of also shown >21mb.
Do you not know the difference between the burner pressure test point and inlet pressure test point on that Potterton Profile? Clearly not.
I just had another look with a full screen Youtube vid. Wow they did take the burner pressure which is to the right of White Rogers control valve. I cannot believe this. I am shocked! These GasSafe men are not competent?
So you required a “full screen” in order to ‘clearly see’ that the manometer tube was connected to the burner pressure test point as opposed to the inlet/working pressure test point which is located to the left side of gas valve? Lol what a fool.
