    Dismiss Notice
combi v system
Discussion in 'Plumbing and Central Heating' started by rhinosaw, 1 May 2019.
  1. fixitflav
    fixitflav
    20 Mar 2018
    686
    Thanks Received:
    56
    Stoke-on-Trent
    Country:
    That's the way to do it! If the 18mb is mandatory you would expect W-B to be aware of it.
  2. Sponsored Links
  3. hard-work
    hard-work
    14 Jul 2016
    1,797
    Thanks Received:
    37
    Country:
    I assume they never touched the meter at all. If they did wouldn't they say so?
  4. ianmcd
    ianmcd
    15 Aug 2010
    14,704
    Thanks Received:
    4,963
    Lanarkshire
    Country:
    on Guernsey the gas meter pressure is 14mbar and the lpg/air supply CV is 625 below half of Nat gas, the outlet pipes to appliances are sometimes 2"
  5. Grumpy Gasman
    Grumpy Gasman
    6 Jun 2018
    96
    Thanks Received:
    8
    Buckinghamshire
    Country:
    Fixitflav & hard-work clearly show their incompetence when discussing gas related topics.
    The YouTube video clearly shows the manometer measuring the gas burner pressure and not gas working/inlet pressure on the Potterton Profile boiler.
    The 3 bods in that video are a bunch of clowns (I personally know them) as is fixitflav and hard-work.
    • Thanks Thanks x 1
  6. nwgs
    nwgs
    19 Aug 2014
    6,920
    Thanks Received:
    1,890
    Lancashire
    Country:
  7. Grumpy Gasman
    Grumpy Gasman
    6 Jun 2018
    96
    Thanks Received:
    8
    Buckinghamshire
    Country:
    Ian Puddick MD of the London Boiler Company also boiler expert to BBC, ITV & C4.
    Well well well, you couldn’t make it up.
  8. hard-work
    hard-work
    14 Jul 2016
    1,797
    Thanks Received:
    37
    Country:
    Clown, they said it was working pressure. Listen again. They are all GasSafe men, like you, so they must know what they are doing. Do they?
  9. Grumpy Gasman
    Grumpy Gasman
    6 Jun 2018
    96
    Thanks Received:
    8
    Buckinghamshire
    Country:
    The working principle of the zero/1:1 governor does NOT “draw the gas through the pipe” as stated above.
    Fan pressure whether negative or positive acts upon a diaphragm (offset) and in turn regulates the volume of gas to burner/mixing chamber by bleeding-off pressure to the underside of working pressure diaphragm.
  10. Sponsored Links
  11. Grumpy Gasman
    Grumpy Gasman
    6 Jun 2018
    96
    Thanks Received:
    8
    Buckinghamshire
    Country:
    It clearly wasn’t “working pressure” but “burner pressure” that they were measuring on that Potterton Profile.
    The inlet/working pressure on that Potterton Profile would of also shown >21mb.
    Do you not know the difference between the burner pressure test point and inlet pressure test point on that Potterton Profile? Clearly not.
  12. hard-work
    hard-work
    14 Jul 2016
    1,797
    Thanks Received:
    37
    Country:
    I just had another look with a full screen Youtube vid. Wow they did take the burner pressure which is to the right of White Rogers control valve. I cannot believe this. I am shocked! These GasSafe men are not competent?
  13. hard-work
    hard-work
    14 Jul 2016
    1,797
    Thanks Received:
    37
    Country:
    It depends on which control valve fitted - Honeywell or White Rogers?
  14. Grumpy Gasman
    Grumpy Gasman
    6 Jun 2018
    96
    Thanks Received:
    8
    Buckinghamshire
    Country:
    So you required a “full screen” in order to ‘clearly see’ that the manometer tube was connected to the burner pressure test point as opposed to the inlet/working pressure test point which is located to the left side of gas valve? Lol what a fool.
  15. hard-work
    hard-work
    14 Jul 2016
    1,797
    Thanks Received:
    37
    Country:
    Do you mean it was not connected to the burner?
  16. Grumpy Gasman
    Grumpy Gasman
    6 Jun 2018
    96
    Thanks Received:
    8
    Buckinghamshire
    Country:
    You tell me.
  17. hard-work
    hard-work
    14 Jul 2016
    1,797
    Thanks Received:
    37
    Country:
    You are doing the telling.
Loading...
Share This Page
