I have a Wylex NHRS6604 board which has a dedicated 32A cooker circuit, with a 20A double oven running on it.
I want to have an induction hob installed, which is 32A (7.4Kw). There are two circuits for the sockets in the house, which are both 32A.
There are two unused slots on the board, so I will probably have to get an electrician to install a new circuit for the induction hob in one of those slots.
I did wonder, though, whether it would be possible get them to, instead, just up the rating of the oven circuit, to accommodate hob and the oven (total of 52A). I noticed that you can get breakers that go up to 63A.
The existing cabling is 6mm, contained in conduit, in the wall for about 2 metres. I think that would be OK for 52A but not the full 63A.
Is it possible to upgrade the circuit to 63A and would that require them to upgrade the cabling? (if it needs upgrading, then a new circuit is probably just easier)
