Insulating between battens on Victorian terraced house
16 Aug 2010
Buckinghamshire
I've removed the old lathe and plaster from my Victorian walls and plan to batten out and use 12.5mm plasterboard. Can I insulated between the battens? What's the best material to use?
In my 1930s house I stuck Kingspan on the walls with Everbuild pink dry fix foam, and plasterboard stuck over this (with a few mechanical fixings going into the bricks), all joins sealed with insulation tape.
Sold, warm, vapour control.
You can use insulated plasterboard. Do your wiring first, preferably in conduit so later additions or alterations will be easier, especially in a kitchen where there are lots of outlets and some time-saving methods. Battens are not essential, but useful if the walls are not flat and level.
I am confused, the walls were lath and plaster. Why not just use rockwool in the cavity?
Surely these are internal walls? I have never seen lath and plaster used on external walls.
Had it in the bays of an Edwardian house. May have been to save weight.
My neighbour has a flint and lime Victorian house, two stories high, with brick quoins. the flint is not very stable and parts of it had to be rebuilt by a local specialist, There is a L&P inner wall battened to the flint. The builder was able to dismantle and rebuild the flint while leaving the original L&P in place. he used props and studs while working.
Not too many of those here in west London. Mind you I did recently quote to do some work at the only house in Ealing with a thatched roof- AFAIK that is the only one in a stock of approximately 130,000 dwellings.
In my small town we also have (at least) one building with Mathematical Tiles.
I like to point it out to visitors who think they know about building.
I had no idea that such a thing existed, tnx (again).
as above. definitely use insulated plasterboard but build it out, if necessary, with adhesive. try and stay away from mixing with battens.
but, even with previously battened walls, before pulling out any wall(s) think it through esp ref reveals, frames, devices on walls, and sometimes doors - remember the p/b must be plumb and in plane and have 90 degree corners.
and check for any damp signs - if the exterior is rendered then come back here.
It was more to save cost - you see it quite a bit in stairways, alcoves, etc in larger Victorian houses and shops, but it is pretty rare in smaller terraced houses of the period (at least in Lancashire, Yorkshire, etc - and in my experience)
I've seen it a few times on better quality houses of that era.
I thought it was to keep the internal walls dry being solid brick construction.
If it was my house I would use the honeycome damp proof membrane and then as Bob say's insulated plasterboard.
For any given thickness, the most efficient insulation is silver foil backed eg celotex/kingspan/xtratherm etc. And if you are going to all this trouble, why use any other type?
And it's always best to insulate in a way that does not impede on the internal face if possible. But there should always be a thin layer across the face to prevent pattern staining from the timber battens.
"there should always be a thin layer across the face to prevent pattern staining from the timber battens."
Sorry Woody, what does that mean? I do not doubt that you are correct, I just got a bit lost. Tnx
